Eunos 800M Manufactured by Mazda..
95/96 model
This is the flagship model featuring every conceivable option, no expence has been spared, this vehicle was priced at over $60,000 when new and released to be direct competion with BMW and Mercedes of the same era.
Featuring:
* 2.3 Litre Millercycle Supercharged V6 (as standard)
* Automatic with optional manual shift
* 4 Wheel Steer
* ABS
* Driver and Passenger Airbags
* Climate control A/C
* Bose 5 speaker surround sound with cassete and 6 stacker
* Power windows, mirrors, seats
* Electronic retractable mirrors
* 2-way sunroof
* Complete leather interior (front+rear+doors etc)
* Woodgrain inserts
* The vehicle has a feature that allows automatic regcharging of the battery through solar panels factory fitted in the sunroof
* Near new 18-inch chrome wheels
* Long Registration
This vehicle is in excellent condition and i have receipts for all work that has been done whilst in my care, the engine is mechanically A1.
It is a dream to drive, having both a very, very smooth ride and the availability of fast acceleration when needed at the same time is the most economical v6's i have ever driven (more like the fuel consumption of a 4 cylinder). It is a very elegant and stylish vehicle to drive and for the price
you would be very hard pushed to find anything else with these amount of options and to this standard of design on the market,
INSPECTIONS WILL NOT DISSAPOINT.
$14,500 ono
Enquires to-
0409288899
[email protected]
I do understand this is not a wrx , i have been a member on here for quite sometime now and have previously owned wrx's so i thought id give it a try- thanks.
****pictures are available, have tried hosting several time to no avail so if anyone could host for me it would be greatly appreciated*******
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
