  • Replies 315
no dickheads, shit, screw you man i wont come then................:cheers:
slide and daler32, apperently us goldcoasters are crap readers, lol- sorry erin, follow me there if ya not sure where to go, im goin up from currumnbin
Erin i dont know where bp is or Aussie carpark or the beenleigh tavern i only know where the pie shop is cause you told me
so i deffinately dont know where the carpark is or bp or the tavern for a landmark refference i were using yatla pies and awaiting directions from there
sorry for confusion
near pbc high, or the river or sorta kinda over that little bridge and near the primary school
around that area, close to the beach???....................hahaha
yeh around there:) do u know were im talking about?
Rodney, you're one in a million...
*sigh*
Okay Gold Coasters who are scared about getting lost getting to Aussies Carpark.
I will be at The BP Coomera (the one across from Dreamworld) in the small carpark in front of the bowsers at 7.55pm. I will be leaving at exactly 8.05pm and I will take you FROM The BP Coomera (the one across from Dreamworld) in the small carpark in front of the bowsers, up the highway all the way to Aussies Carpark.
Make sure you have the obligatory amount of petrol and a UHF radio before 8.05pm or you will be left behind :rant:
Nexus9 out.
i dont know, last cruise i went to, i waited at commera bp for like 25 minutes and no one came:(
then i was supposed to exit at springwood craxy clarks but i ended up neally in sunshine coast?
thats wat happens when ya fellow skyline members arnt there for you, so dont listen to him slide
hahahahahahahahah
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
