Can anyone tell me the easiest way to find the speed sensor for my greddy turbo timer?
I heard it is wire 53 but how do i find it and should it come off the dash or computer?
can anyone show me a pic of it or something
thanks
ed
https://www.sau.com.au/forums/topic/62365-speed-sens-wire-for-turbo-timer/
  • 1 month later...
Ihave the same issue with my BlitzMSTT, except i found the wire....yellow with green stripe from memory......but it reads at HALF SPEED, so it kindamakesall the nice functions useless, ivebeen inside the dash an with no speed cut defender to find.....i dunno what the go is?
My only figuring is the my Nismo 300Km/h speedo is a SCDefender itself?
good luck!!
