*** Tsunami Cruise for Charity. Combined Club Mega-Cruise *** 13th Feb.
In response to the recent disaster and the ongoing need for international support, the Victorian Car Enthusiasts community has expressed a desire to help out. Well, here it is.
Skylines Australia, Commodore Cruise Club and (insert your club name here) would like to invite you to one of Victoria’s biggest cruise’s yet.
Date: 13th February, 2005
Time: 11:30 am for a 1:30 departure
Crn Canterbury Road and Heatherdale Road Vermont.
Enter from Heatherdale road.
Destination: T.B.A on the day.
Maps $10 with all monies going to the Red Cross
On the day there will be BBQs and media coverage.
This event is being supported by the Red Cross of Australia.
THIS IS A DISPLAY CRUISE; ABSOLUTELY NO STUPID BEHAIVER WILL BE TOLERATED. This is a chance to show that we aren’t all bad.
So shine em up, and bring em out.
Have a look at some of Victoria’s best looking cars all together for this great cause.
Spread the word
Due to various reasons, Commodore Cruise Club and Skylines Australia must change the nature of the Charity Event being held on the 13th of February 2005.
We are unable to run a mass cruise as such due to legal, liability and logistical reasons. There aren’t many places that hold 1000 cars at once!
We will therefore be changing the event to a SHOW AND SHINE where everyone will be able to meet and greet and check out some serious metal.
The Manhattan will still be the venue for this event and we will still be running a BBQ and having a great time.
The Australian Red Cross will still be involved and all donations go straight to them.
We will be at the Manhattan for a bit longer, probably until about 4pm which gives everyone more time to check out all the cars and bikes in attendance.
Everything is the same as before, we will just not be able to go on a mass cruise.
HOWEVER, each car club is encouraged to run their own cruise from the Manhattan leaving at about 4pm.
As said above, we can still cruise, but just not as a huge mass.
Commodore Cruise Club and Skylines Australia will be cruising on from this event on their own cruises to various locations.
We still want this to be an event which will be a huge success for the Tsunami Appeal and during the next two weeks, we will be adding difference things to the day to make it just as much fun.
We encourage each car club to cruise TO the Manhattan, so start organizing your “pre-meets” and cruises to the Show and Shine.
Again, apologies for the change in event type but this will still be a huge event to don’t stop polishing those rides!!
Cheers
Demnvt and Bass Junky
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
