I had a stock R32 that made 115rwkw, stock everything.
125rwkw with fuel leaned out a little on 95RON fuel.
This was done with a bleeder on the FPR.
95RON fuel wouldn't allow any more than the base 15degree's ignition timing.
The exhaust went on, power went to 140rwkw with no fuel fiddling, only ignition timing & 98RON fuel.
12.5psi gave me 152rwkw with a bit of ignition timing & fuel bleed with 98RON fuel.
  • Replies 61
But i've seen a couple of guys running that sort of boost level through stock RB20 - No Intercooler/Dumpipe and their turbo hasn't died yet!
Jun
Hey, i would be a fine example of that...
same mods as above 3 inch cat back exhaust, air filter.
lately these cold nights i've been getting constant 15psi runs and during the day about 13~14psi
Still have the same stock from cooler in the left hand side, no boost controller..yet
running fine
how do u run more boost like 14-15psi with out a boost controller HCR32?
mate im asking my self that same question
i know r32gtst run stock 9~10 psi, with after market exhaust and air filter you can expect it to jump up to a higher psi reading like 12ish
but as i said above, cool nights, keeping an eye on the boost gauge its hitting 14~15psi and holding strong.
Some people might not call a bleedvalve a boost controller... could be one reason :D
Either that or you could do a bodgy mod like this.. :)
Grab a big arsed Yellow screw driver and ring spanner.
Loosen off the actuator bolts jimmy the actuator away from the turbo and tighten up the bolts. Be carefull with the right foot as just a little too much adjustment will easily see 18+psi. :)
With this setup I didn't need any form of bleeder or boost controller.
It also held any boost level to redline and beyond. Bleeders would tend to drop back to 12.5psi over 5500rpm. EBC's held boost, this free mod does what an ebc does. :D
so if i create a GAP between my actuator n turbo? how much boost will i be running?
I mentioned it in my previous post..
Be carefull with the right foot as just a little too much adjustment will easily see 18+psi. :D
No one knows how much boost you will be running.
You have to try and becareful.
If you don't feel confident playing then don't do it. You WILL blow something up if you are not carefull.
hahaha
So a standard rb20 turbo can run 15psi ok(occasionally of course)? When does the power start to drop off at, 6,000rpm similar to s13s?
Whats the redline on an rb20 btw...
Also what kinda 1/4 times wud u be getting with 15psi + fmic + full zorst (im guessin 150rwkw and flat 14s)??
R32s seem to be a backwards step in power from my old 180 but they look better... hehe
hahaha
6000rpm power would seem to drop off because of cams. I have found keep going to about 6250-6500 just to keep it in the power a bit more on the gearchange, but thats with my car.
Id hope with those mods tho you would be getting more power than me... I have stock cooler, and 12psi, and got 145rwkw on a hotish day, at what would seem a pretty spot on dyno. I've also run a 14.156 in a car that is about 150kgs heavier.
So you make 145rwkw on 12psi with a full zorst? Im guessin the 14.1 is in the 32?
Im buyin an r32 and tryin to know what to expect :D
Nah, sorry, no dump pipe yet. Just stock dump, rest is prety much 3inch straigh bit of pipe, I think one 30* or so bend after the front pipe.
And no, time is made in a cefiro, with pretty stiff suspension.
Jazz.
I always rev'd my RB20DET to a shade over 7000rpm. BUT with stockish boost it feels as if you want to change around 6500rpm.
More boost helps extend the top end for some reason.
I posted earlier in this thread, Full exhaust & 12.5psi it made 152rwkw.
1bar made 164rwkw at 7000rpm.
I then pushed it to 1.1bar and used to run 0-100km/h in ~5.2secs and 175km/h in the 13's. So I'd say it would have been in the high 13's.
R32's weigh in at just over 1300kg's.
R33's weigh ~1400kg's.
Is the actual redline 7k or 7.5k on the tacho? People seem to say RBs (and CA's) can rev better than Sr20s... yet an sr20 redline is 7.5k, is the RB the same? Obviously i know these engines are simply happier at those higher rpms too :D
Cef... Weight 1330kg
R32.... Weight 1290kg
But then, mines got the skyline brakes, bit of stezza gear, all my cds (about 400 odd in the car all adds up :D) bigger fuel tank, few other upgrades/extras abs etc, and I had the air compressor etc in there for after races.
So yeah, do the sums.
The solid redline is at 7500rpm. It begins to show a warning redline at 7000rpm.
The tachno means crap but.. :D
Fit a big turbo and rev the sucker to 8000rpm. :D
I've driven a S15 making around 170rwkw, fmic exhaust & ebc.
That definitely didn't want to rev anything like the rb20.
The Sr20 felt as if it was begging you to change at 6000rpm. The RB20DET keeps saying.. just a little more just a little more. :)
For traffic lights I much prefer the sr20. For the twisties and hills the RB20DET is much more fun and usefull with its revability and wider power band.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
