  • Replies 40
All too true.
The car made a cameo appearance down here in Coffs last weekend. I too have heard that the car is quick, but outside of it being a GTST, I have no idea.
I have seen it run against a laser with a t04 turbo, lets jus say the laser waved byebye to him.. hence not so quick.
https://www.sau.com.au/forums/topic/62432-dragme/#findComment-1178814
yes i know the owner his name is martin and he's spent shit loads of money on the car it has the works, big turbo and much more. car still only has standard internals (or so i'm told) it ran my mates 33 at willowbank and i was suprised at what time it ran, thought it would be quicker for the amount of money that has been spent. i think he's still sorting the performance of the car out.
https://www.sau.com.au/forums/topic/62432-dragme/#findComment-1178835
:wavey:
Good to see someone else on here from the Mid North Coast.
https://www.sau.com.au/forums/topic/62432-dragme/#findComment-1181313
DRAGME was sitting in 101motorcafe for a very long time.....dont know what's done to it though...but there was rollcages in the car
101 Motorcafe are not know for producing powerful/fast cars. They do normal service work and fitting of aftermarket bolt-on parts. Yes the owners have fast/powerful cars but that not the result of them doing the work themselves (at 101). Its the result of them taking it to a workshop around the corner from Autobarn at slacks creek. So if there was any work done on DRAGME, it might have come from the same garage....
https://www.sau.com.au/forums/topic/62432-dragme/#findComment-1185634
this is my girlfriends account..but i know martin with the r33 DRAGME and this car is a sweet car its just a gts-t s2 and its had some work its a good looking car if uve seen it but his guy has the money to do what ever he wants to it so i wouldn't be surprised if this car will be soon be the fastest car at redlands bay...but i would be careful wat u say about this guy...if u know him hes a cool guy but if u dont know him and say sh*t about him thats a bad move.
https://www.sau.com.au/forums/topic/62432-dragme/#findComment-1185660
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
