New Cabramatta Meetup Cruise Date!!! 7/12/02
  • Replies 312
Originally posted by ENVGSR
we should set a time! and also state what cars we will be in. i dont want to be standing on the other side of the car park wondering if those guys across there are the ones from the forum. would like to say hi!
Tai you bring your friends out again like last time?
Originally posted by GTR-80Y
Yeah wheres my msg woman???
Wheres orange grove?
Jordan: Goin with GF and dazsta.....we like 3somes!:O  I'll be there for a month and a bit, roaming the freewayz.
hey whered I come into!? whats going on?! hehehe
u can piss off loz, just leave me with your GF :shake:
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
