1997 R33 GTR V-Spec - When the engine is cold and temp setting at 18c cool air comes out the dash vents. When the engine is warm or hot and temp setting unchanged it blows warm air out the dash vents (warmer than outside temp) If a/c is turned on for say 30 secs then off it seems to help but still is not same temp as outside. Anyone got any idea's ?
https://www.sau.com.au/forums/topic/63110-hot-air-from-dash-vents-on-r33-gtr/
I had a similar problem check that your interior temp sensor is connected and working if not that will automatically go to hot. If its not that its prolly the tap that opens and closes to control hot water to the heater.
i had this problem too, its aparently a common problem on the r33's the motor that opens / closes the valve for hot / cold air is weak, and breaks after a few years operation, my car was doing it when i bought it so it was replaced under warantee, luckily, as the entire dash has to be removed to change it, well entire dash if its has a passenger airbag ..
at least this is what justjap in kirawee told me ..
the new motor itself is not expensive, just the time to do the work .. i remember seeing an article on howto remove the dashboard of an r33 - not sure if it was on this site - do a search, it was a red r33
cheers
the thing tang0 is talking about makes a clicking noise when you turn on your car... not sure if that has anything to do with it... try what Godzilla32 said... the interior temp sensor is just behind the plastic dash surround (that has all your stereo etc in it)... just below and to the left of your steering wheel you will see a small vent (horizontal lines) behind that there should be a black tube going to it and a plug with some kind of electronic component :D
Best bet would be to try the diagnostics on your climate control, withing 10seconds of starting your car, hold the off button on the climate control for about 5 seconds i think...
more info in this book:
http://gtr.ferni.net/misc/skylinebook.pdf
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
