Hey guys
I have 3 new Intercoolers for sale AT UNBEATABLE PRICES!!
Intercooler No. 1
This intercooler is new in-box Hybrid Special Edition Intercooler.
The cooler has some very minor imperfections:
- Small bump on the top left plate
- Some ruff paint (Hardly Noticeable)
Other then that the cooler is in perfect condition.
Specs:
Core: Bar & Plate
Core Size: 600 x 300 x 76
Pressure Drop: 20PSI - 18PSI
Heat Exchange: 72C - 22C
GREAT DEAL FOR ONLY $300.00 DELIVERED STRAIGHT TO YOUR DOOR !
Picture 1 / Picture 2 / Picture 3 / Picture 4
Intercooler No. 2
This intercooler is new in-box Hybrid Copy
- Some paint has come off the core
- The white stuff on the core is the packaging foam that is stuck to it
Specs:
Core: Bar & Plate
Pressure Drop: 20PSI - 17PSI
Heat Exchange: 72C - 24C
NICE AND CHEAP FOR $220 DELIVERED STRAIGHT TO YOUR DOOR !
Intercooler No. 3
The cooler has been sprayed darkish silver colour
The cooler has a very minor imperfection:
- The top left plate has been pushed in
Specs:
Core: Bar & Plate
ABSOLUTE BEST PRICE FOR $200 DELIVERED STRAIGHT TO YOUR DOOR !
If you would like to take one of the coolers home:
PM or email me : [email protected]
*CLICK HERE FOR PAYMENTS AND HOW TO BUY*
:P
Hey guys,
Consider IC3 sold. Couldn't pass on a price like that.
Alex said would post COD yesterday morning and my Wife picked it up at 9:00 am today.
Looks good. (Exactly as per pics)
Very happy.
I see kits are now coming through for $550 the lot. Sounds like a bargain to me.
Enjoy !
El Bee
