I have recently done the high mount upgrade on the 33 GTR but not thinking about we used a set of 32 GTR O2 sensors (I steel wheeled 32 GTR turbos) Since then the 33 has been running a bit rich and in my pursuit of finding the problem I have used my multi meter and read the resistance across the O2 sensors. on the 33 one's i get 4.3 ohms across two of the three termnials. My engine is dead cold and the 32 one's that are on it read 7 ohm's. Are these correct reading's do 32's use a different sensor cause externally they are different. if so it would read different on the computer and it would adjust itself to suit, making the car run rich??? cheers for any help
https://www.sau.com.au/forums/topic/63813-r32-r33-o2-sensor-readings/
You can't test O2 sensors by measuring the internal resistance.
They are both 0-1V sensors (narrow band)
So provided they both have the same plugs and wiring pinouts, they will work fine.
The newer O2 sensors will provide a faster sample rate during closed loop operation, therfore getting maximum economy. If you know which ones have done lower km's use those ones.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
