Guest Boxhead
im just curious, but having an non turbo car, and not looking to turbo it, im wanting some ideas on how i can make it better, as in, better performance, and last longer etc.. i would like to know the cheapest way i can get the car going nicely, and looking good.. all those little things you can do to make your car better
https://www.sau.com.au/forums/topic/639-cheap-mods/
Cheapest option is a good cold air feed and good filter not necessarily a pod either!! Then a good exhaust system, proper tuned length extracters to if you can afford them. Then id say a computer, then cams and head work then individual throttle body injection, then crack the motor start reworking things, stoked bored, cross drilled crank, knife edging the list goes on.... Too look good just put on some nice biggest you can get wheels and lower it that should do any car some justice
https://www.sau.com.au/forums/topic/639-cheap-mods/#findComment-15202
keep in mind a pod is illegal. if you are going to do it make sure you partition it off from hot engine gases. a cheap industrial type insulant can be bought for $5 and if you do a good job of it it can give you a kw per $ return.
check this out. once bonnet is closed, it creates the desired boxed effect. do not forget to provide air feed.
https://www.sau.com.au/forums/topic/639-cheap-mods/#findComment-15664
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
