Well my first time back at wsid in about 8mths with high hopes and that's where it ended. My car is now running better than ever and once again I still couldn't grab a decent time, I feel like headbutting a brick wall :(
I did manage to get a new PB but only by literally a bee's dick.
1. 14.489 @ 94.84mph / 2.190sec
It felt nice and smooth, launch was the usual but for some reason I was -way- down on mph, I didn't even miss a gear :D
2. 15.265 @ 100.23mph / 2.737sec
First run after a 30min rain period. Absolutely no grip on the greazy track and simply bagged em up!
3. 14.145 @ 102.07mph / 2.167sec (<- new PB)
Tried to slam the gears harder, felt smooth once again and managed to get a new PB (old PB was 14.163 @ 100.20mph / 2.148sec).
4. 14.252 @ 100.87mph / 2.166sec
Once again was trying to work the gears hard but was slightly slower even though it felt just as good *shrugs*
5. 14.571 @ 98.02mph / 2.184sec
Used low boost this time (7psi) just for shits n giggles (even though high boost is only about 8-9psi haha).
As you can see my launches are pretty much spot on everytime (even though 2.1xx sec is not overly impressive atleast it's consistent). Sure I could grab some semi-slicks or even drag nitto's etc and probably shave off a tenth or 2 but I shouldn't need to when i'm making a solid 195+ rwkw. I'm a good 0.5sec off the pace of where I believe I should be (and the times others are doing in similar powered cars) and im stumped as to what it is (obviously it's the driver).
Was a great nite of racing (besides the rain periods). Some awesome cars about and probably the biggest meeting i've seen in a good 5-6mths. Wish I left my car in the carpark and spectated instead.
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203612
i only ended up getting 240RWKW
need to lower compression gonna get a steal head gasget, that will bring her up to the 290 mark.
im gonna buy some slicks soon, just gotta find out how to fit them without removing the brakes, 16" is the only size that can go on.
any1 know where i can get piks from last night??????
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1203992
mods
td06 20G
Greddy Manifold
HKS 50mm External Wastegate
FMIC
Custom Plenum
550cc Injectors
600HP fuel pump
Nismo GMAX twin plate clutch
Power FC
Q45 AFM
KN Air filter
Sard Fuel Pressure reg
Coming
Head gasget
Forgies
Rods
Cams
Big F**K off turbo
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204002
Sorry mate as I've said several times in the past the 20g wont flow enough to make 290 its impossible, maybe some decent drag radials would be better then slicks as then you don't have to worry about the added cost of front runners
https://www.sau.com.au/forums/topic/64153-wsid-9-2-05/#findComment-1204051
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
    • Hello everyone, I'm glad to join you.
    • Definitely do-able haha. I will give it a try if the fuel pump hanger does not solve the issue. Just need to find some quiet time in the area, Malta is like a big city and I live right next to the main hospital so it is very busy during the day. I'll be installing it in about 2 weeks, found a garage that is pretty knowledgeable and has the necessary tools. This garage has worked on multiple builds, even for competitions. They even asked me to stay with, so I should be fine.
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
