NSW Custom number plates: R33GTR Black on Yellow, no hyphen they are the proper custom plates, Brand new waiting at RTA for 2years now. Must be sold
Show off your ultimate R33 with these plates they say exactly what the car is with no short wording.Extremely hard to find type. Owners can always change the colour of plates if they don't like but the Black on yellow stands out the most. Asking price: $4000, offers welcome from any price.
https://www.sau.com.au/forums/topic/64361-r33gtr-plates/
