HI All,
I have been thinking about selling my r32 for a while now since i am going to drop down in power to a stock r33 and start working on that.
My 1989 (october build) r32 has a fair few goodies that hopefully will impress someone.
Below are the Specs:
Under Bonnet:
RB26 block - Strong as a rock
RB25 Head
Trust TD06 - 20G turbo with external wastegate
3" exhaust from dump pipe to exhaust
High Flow cat (Brand New)
r33 front and rear brake calipers and rotors.
HKS pod Filter
Aftermarket Suspension
Aftermarket Fuel Pump
New Oil Filter
New Fuel Filter
New Spark Plugs (plus throw in another 6 platium's gapped @ .8mm)
Strut brace
Interior:
Alpine Double Din headunit
Aftermarket Steering wheel
Sunroof (no leaks)
Rear strut brace
120,000 on the clock (Engine has done alot less)
HKS boost guage (white faced)
Apexi Pen Turbo Timer
Exterior:
Motoristed Front lip spoiler
Spoiler removed (still have tho if you would like to mount back on)
Stock r33 rims with new tyres.
Car would go for around 15000 - 16000. Depending on what mods i add to this as
i have 18 inch wheels, FMIC, dual boost controller, short shift kit, and a few other goodies to add into this if the buyer would like.
When the car hits boost, which is approx 4,000 it lights up.
This is a good modified car, which will please the buyer.
Car revs out to 9,000 and does come with Dyno sheet of 235rkw.
Car also comes with 11 months rego. As only registered last month
hence the pictures have ne plates.
I will get some more new pictures tommorrow
Cheers,
Brendan (0423 324 913)
https://www.sau.com.au/forums/topic/64454-for-sale-r32-rb25det-with-mods/
hey, u got any other pics of the car, maybe some of the interior. The power figure it pulled, was that with front mount and other goodies or the way the car is now. How much would u consider selling for with all goodies on the car. Could u forward any other info to [email protected]
Hi guys,
Im a personal friend of z3n2k and I dont think the car had a front mount cooler on it to be honest. It only runs the standard side mount, but he would obviously know more about the car than I do.
The car came with a dyno figure of 230rwkw and is a pretty quick car!!! Laggy turbo tho, not after 4k :D
hey swap for wrx my03 33kms sliver no mods
Hey people, please dont post if the car has been sold or has been pulled off the market, it gets a bit annoying.
/rant
Gday mate are u still keen to sell this car?!?!? i have been looking for 32's for a longtime now!!! im ready to buy a decent tidy r32, when ever.... so let me know if u r still selling it and i would like to come and check it out. thanks mate..
Cheers
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
