Hi all,
Thought I'd start this thread to try to help out anyone who has problems with the backlight on their climate contol unit.
Mine was 1/2 gone then after replacing my stereo it was totalled ! I realised that the globes are replaceable after reading NZSTAGEA's post on the stereo replacement thread but had heaps of problems finding replacement parts.
I went to a number of auto electricians, dicksmith, jaycar, nissan, and a couple of hobbie shops and was unable to find a bulb that had long enough contacts. I was in another dicksmith store for something completely different and after rummaging through their electrical compoents I stumbled on one that looked close.
I have now fitted two new bulbs and the unit is working properly. The part details are as follows:
part number: P8140
Description: Globe, 12v, 50ma, 5mm wheat grain
Price: $1.28
To fit the bulb:
*Follow stereo replacement directions to get the CCunit out
*unscrew the bayonett fitting in the top of the unit.
*remove the rubber bulb covers carefully
*unhook the bulb wires from the bayonett fitting & remove the bulb
*fit the new bulbs in the bayonett fittings & wrap the contact wires around the inside (side that the bulb is on) of the fittings.
*replace the bulb covers ^
*replace the bayonett fittings
*replace the CC uinit
^ optional - I lost one of my covers so did not fit the other and the unit works fine (but backlight is now orange !)
https://www.sau.com.au/forums/topic/64577-climate-control-part-number/
Another query with aircon...
only a minor annoyance - but stag is first car Ive driven where the climate control doesnt keep memory of the aircon setting when u switched the car off... every time u get in the car it is by default switched off... just irks me coz if I hop out, pop into a shop - pop back in and turn key - it doesnt go back to my preferred aircon setting i just had... so i have to switch it on, readjust it etc every time...
So yeah - any1 know of anyway around this - so that when i turn the car on it is on the same aircon setting it was when i last turned the car off???
:D
Check your fuses. I had this problem when a fuse had blown somewhere, but i forget where.
Make sure you check for continuity with the fuses, as sometimes they look fine but are actually stuffed
Could be a fuse issue as Terminal says, could also be a wiring problem. I believe the climate control unit has a 12V feed from the battery when the car is off (v. low current) to maintain the last set temp in memory. So it could be that this feed is either disconnected, or someone has bodged the wiring and connected it to the ACC feed.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
