All depends on how much of a risk the engineer signing off your car is willing to take. for example we've had one engineer refuse to sign off a client's RB26DETT single T78 turbo setup because it was too different from stock and it'd need emissions testing before he'd put his name to it, so we contacted another engineer who signed it off without even glancing at it. But the second engineer was more concerned than the first about the quality of the side intrusion bars (he wouldn't sign it unless the bars were welded onto the car instead of just bolted on).
So yeah, all depends on your engineer and what they are more concerned with when signing off a car.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
