OK, so I am staring to get sick of 200rwkw and would like to increase the power up to about 250rwkw, my car is a r33 gts-t series 1. I have a plan for this but first here are the Mods that I currently have made to the engine.
  • HKS Pod With CAB.
  • 3' turbo back zaust.
  • FMIC.
  • APEXI Boost Controller (PFC).
  • APEXI Power FC Pro.
  • Adj Zaust Cam Gear.
  • Ceramic 5 Puck Clutch.
  • Oil Catch Can.
  • NGK Irraway 7 plugs.
  • Supra Twin Turbo Fuel Pump (Jap Spec) It sould be up to the task.
I think thats it...
So heres the plan: Get a GCG 450hp Hi-Flow, Nismo Fuel Pressor Reg, Z32 AFM and a re-tune...
I was thinking of other options instead of the hi-flow which include GT-RS, GT25-35, GT28 etc etc but from what I have heard the hi-Flow should make 250rwkw and is cheaper and easier to fit, plus its EPA friendly :rofl:
The big factor here is going to be funds (I dont have a money tree :{)
Sorry about the longish thread... Any comments will help
https://www.sau.com.au/forums/topic/64629-my-next-mods-comments-please/
I have everything but the bigger injectors and really dont want to spend the money on them at the moment. Who is Dyno Dave and has he tuned hi-flows to 250rwkw before??? I think Sydney Kid said that he had a couple of rb25's make 250rwkw with hi-Flows
if you pm deatschwerks (David Deatsch [[email protected]] ) he can sort you out with a set of 550cc injectors at a V reasonable cost ... like half of hks type price ...
anyway, dave tuned my car and got 240kw at 13 psi with a gcg high flow .. basic mods are fmic, pfc, 550's, high flow, 3" turbo back, pump, pod
not bad really ... dave really is a total whiz when it comes to finding horsepower !
if he has not tuned it before, then its prolly not worth tuning as far as i can tell ...
Not really interested in the injectors at the moment guys, I know you can get 240-250 out of the stock ones and i dont have a spare $700 to spend on something I dont really need.
So far it sound like i should go for:
Z32 AFM, Fuel Reg & hi-flow tuned by Dave...
Is there anything that I have left out that I may need (excluding injectors :rofl:)
I'd go
Z32 AFM (cos you have too)
Hi Flow (cos you have too)
Fuel Reg (cos you have too)
Cams (so the power curve is fat like yo mama)
SK has those car doing 250+ with cams.
BASS OUT
Dont think I can afford the cams at the moment.
So far the setup will cost as follows:
1) fuel Reg (about $180)
2) Z32 AFM (about $300)
3) 450 hp gcg hi-flow turbo ($1900)
4) About 250 for a re-tune (local place I use)
Totalling about $2630. I cant afford another $1000 + for cams & install....
Do you thinkt he new cams will push you over the 200kw mark, say 210-215 maybe??? Anything less than that would not make it worth while I reckon...
Cams cost about $750 + at least $250 to re-tune totalling $1000
PS, Who keeps changing my comment above my avatar to rb25de :{
Damn.
 I want somebody to fit cams on a standard engine and turbo to see the results.
 Look's like I'm going to have to do it myself.
bass junk : please do man cause quite honestly id love to see how it goes... cause my next step is getting a restrictor bored to 10psi constant... off stock except POD, BOV... and i cant remember what else, theres stuff all shes pretty much STOCK :rofl:
if only i had the cash id like to see what it can pull myself... but i guess once i start getting cash... this might be a good time for people to start making a thread of what i should do for the first hit of mods and see what it gives ;)
i'm only talking of my experiences here, but ..
a. you dont need a fuel reg
b. the standard afm is fine for the power figures i am running
c. yep, that turbo price is about right - i think i paid that, or thereabouts
d. get someone who REALLY knows his way around a pfc to tune it properly ...
have a look at 'my results' thread i started, 240kw @ 13psi is deffo doable with all the right bits / tuner
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
