Hi Ppls,
I've bought a new camera so my 1year old HP 735 Photosmart camera needs to find a new home.
HP 735 Photosmart Digital Camera, 3.2mp, 15x Zoom, Avi Video with sound which will record until the memory card is full.
Comes with
1 x Camera Bag
1 x Kodak 128mb SD Memory Card
1 x USB Cable
4 x 2300mh NiMH PowerBase Rechargable batteries (Camera only requires 2 AA batteries to operate)
1 x Digitor Universal Charger - Model HL29
It really is an excellent camera and comes with everything to get you and and going with no extra cost.
I bought the camera a year ago for just under $500 + the 128mb Memory card + the camera bag + the batteries + the charger. The extra little bits blew the price out to over $600.
I am after $250. Feel free to make an offer.
I've attached a few pics in low rez and have provided a link to the high rez images which have been untouched (not resized etc).
High Rez Images -
I am located in Adelaide
