Okay i have a set of ROH Drift R's in a 19 with tyres. They are in excellent, excellent condition with over 80% tread left on the front and probs 60-70% on the rears (just a bit worn on the inside could be fixed by rotating the tyre on the rim). They will fit all gtsts including r32 and will fit 200sx with a gaurd roll. They have one scratch which i have posted a pic of other than that they are a steal at this price as they were $4500 new.
https://www.sau.com.au/forums/topic/65613-drift-rs-19x8-19x9-2300/
yeah thats true the width isnt the factor if the rotational diameter is the same attessa will work, do you want me to measure if they are the same????
  • 3 weeks later...
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
