  • Replies 473
no SLOBO......as in SLOW....she is trying to say that he is SLOW around a race track and that he will never beat her.....hence calling him SLOW.
but yeah we all now its a lie....and that slim can easyily OWN her on a race track.......dont underestimate the devo 9
Bwhahhahahahahha
... confusion reins in this battle of SKILL AND POWER...
with the battle lines now clearly drawn.. all that is left for the peeps to choose sides
this truly is the final battle between good and evil....
and im not sure wich way it will go...
SL!M...... Representing the EEEASSSSTSSIDDEEEEEEEEEEEEEEEE
and relying on the race prepped DEVOLUTION 9 to power him to victory..
he grew up on the streets and now hes back to defend em..
MOANIE.... Representing the WEEESSSSTTTSSSIIDDEEEEEEEEEE
moanies RB25.666 powered R33 is shrouded in mystery.. some say that her engine block was forged in the dark funances deep below thornleigh maccas.......
...now for that comment...sl!m will eat you up.
he is dangerous!.....and blonde.
Bwhahhahahahahha
ever thought of writing your own book??
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
