I'll be there - hoping to lower my PB to a mid 13 (or thereabouts) from the 13.9 I did a couple of weeks ago before the car was tuned. Traction will be the issue though - damm Falkens! :)
It would be good to get a heap of Skylines out there on the night and hopefully the weather is dry and cool(ish) - looking forward to it.
https://www.sau.com.au/forums/topic/65764-wsid-2305/#findComment-1228671
it will be fine :rofl:
http://mirror.bom.gov.au/products/IDR032.l...oop.shtml#image
I will be spectating.
Yeah, the radar looked ok mid morning, but it's not looking so promising now...there's rain areas popping up everywhere :rofl:
I'll check it again in an hour's time, but if it's not looking any better, I'll probably give it a miss and look to get out there next week instead.
https://www.sau.com.au/forums/topic/65764-wsid-2305/#findComment-1233833
Outdoor temp here is 22.4c
This time the last 3 meetings its been up around 28c which means hopefully it will be under 20c by the time racing starts :rofl::)
Now all I have to do is workout a way to get my jack/wheels there :rofl:
https://www.sau.com.au/forums/topic/65764-wsid-2305/#findComment-1233905
Sorry guys, I'm out - the radar is showing a heap of showers heading towards Penrith and I'm guessing that it'll probably continue along to WSID as well which is pretty annoying. I was keen to run tonight, but I don't want to rock up to get only 1 or 2 runs (if that) because of the rain. I'll definately be there next week though...
Good luck ben if you still decide to go tonight :rofl:
https://www.sau.com.au/forums/topic/65764-wsid-2305/#findComment-1233970
    • I'd be worried about having to parallel park a boat like that. Magnificent car though.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
