Is there any way that you can turn the fan off on an R32 climate control unit after you have turned it on without switching the whole unit off using the off button. Also how do you enter the auto mode which controls all the heating and cooling of the car automaticly. I see the auto writing come up once i start the air con but how do u actually get it in to the auto mode and get it working.
https://www.sau.com.au/forums/topic/66216-r32-working-the-climate-control-unit/
  • 1 month later...
when u turn ur A/C on hold the 'warm' or 'cold' button down 4 like 5sec's
it turns it in FC(****ing Cold) or FH(****ing Hot) hehe
dont ask me wot it really means,personally id rather rip mine out n let my engine air flow thru
  • 3 weeks later...
FH is Fast Heat & FC is Fast Cold
But F***ing Cold and F***ing Hot discribe the functions better!
Yes it all is a bit confusing. I sat down one day and had a good play just so I could work it all out once and for all. I think I have most of it sussed.
First of all, Air Con cold air actually works better and quicker as a demister than warm air does.
When you first hit the A/C or ECON button this puts it into auto option and the car does whatever it needs to do to get it to the preset temp. If you press the same button a second time it will try and do the same, but without the aircon unit working (basically uses the air from outside to cool down.) You should notice the AUTO display disappear in this mode. Basically, this would be known as the "Fresh" mode on any other car, and is the mode I use the most.
The difference between A/C and ECON? The only difference I can see is that I think the ECON mode has a different temp setting on the thermostat for the aircon unit so it turns off at a higher temperature. This is the case with most other cars with this set-up. It basically takes a little longer to get to the desired temp. It may also kick off when the car has the power put down when in ECON, but I think this actually happens in both modes.
The MANUAL mode gives you the option of controlling the fan speed and vent selection, whilst the car still has the job of getting to the desired temp, again, with or without the aircon unit on.
As far as I know there is no Fresh air option without the fan. I figure they thought that was what electic windows were for.
Now. Go play! :P
i turned my A/C on n had the hot air coming through the front window vents n down on my feet, then turned the A/C off, so now whenever i drive,the hot engine bay air is blown throught the window vents n down on my feet without having the A/C on, if it gets 2 hot i use the electric windows, i find this is most effective 4 my needs:)
mainly coz i stress about fuel consumption n heat around my pod.
That is such a cool thing !!!! ( no pun intended ). Went for a belt on the weekend with both windows down and this little trick activated and my feet were nice and warm while the cold air is in my face. :cheers:
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
