I have a nismo billet (one piece) chromoly flywheel for sale; will suit all RB engines using a push type clutch. It weighs around 6kg; the standard flywheel weighs 9.8kgs. Worth around $1000 new. Asking $400 ono and im bummed that i cant use it.
Also selling a single plate 5 puck cerametallic push type clutch. This clutch will hold around 260rwkw maximum. It has about 50% left on the pads; the pressure plate is in excellent condition (no cracks etc). Asking $400 ono.
I can also have the clutch rebuilt so it is like new for an extra $250 (this involves machining pressure plate, new clutch material and new paint so it looks nice and sexy). The new clutch cost me $875 so for anyone looking for a good clutch upgrade this could be a cheap alternative.
This clutch was built by Carters Clutches in Newcastle and i was extremely happy with its performance. Will suit RB20, 25 and some 26's.
The reason behind the sale is that im building an RB26 engine that will probably require a dual plate clutch.
For any enquiries call Shaun on 0414972596. I can email pics for serious buyers too.
https://www.sau.com.au/forums/topic/66392-fs-nismo-flywheel-and-clutch/
hey shaun,
was that flywheel any good on the rb20?? did it cause any vibrations......or cause the car to loose more than usual speed up hills?
also was that clutch a on/off style clutch?
Cheers
George
Ill e mail pics as soon as possible.
The clutch was firm but ok for city stuff. It has a sprung centre.
The light flywheel increased accelleration heaps. It didnt cause any vibrations at all. Youve gotta be aware that you have one when youre going up hills, but i didnt find it a problem.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
