  • Replies 108
i ***n totally forgot about this hey, i ***n went cruisng in a mates car and saw all u guys at a servo and ***n kicked myself.......................oh well was it good??? did nt recognise many cars in the quick second i saw you all, must be all new peeps
and slide it isnt matts fault that he had a piss week small battery and i am not going to mention wat happen in the car that i was in
:) piss week indeed next time it happens matt ill hook my car up to yours and pump some real power through it :wassup: if it was auto youd be farked like when it happened to me :)
Great night guys. AFRO and myself ended up having some more fun on the the drive home with a pumped WRX. Was good fun until limiter kicked in :Oops: , then I had to make do seeing the other two take off in the distance.
Drop a line when the photo's are posted.
haha what happend with those r34's why did u take so long to get to bwcp and i thought it was like 11, sorry i must get confused with all the circle lights
there was a total of 16 lines, good turn out guys. Slide: shut up biatch, my battery owns yours in its 1337ness :). That and it wasnt really flat it just looks like a racecar with no starter motor when you push start every time ;) hahaha, all up good cruise sorry for anyone who got lost we tried hard to make sure u didnt but this is SAU and as everyone knows someone will always get lost on our cruises :)
hey matt why are u telling everyone to shut up is that ur thing or something cos u have nothing else to say
hmmm right...yea maybe it is i dunno?? Im being sarcastic if you cant notice? That and where are you pulling this "everyone" from?
and as for me having nothing to say i think most ppl can vouch I probably have more than enough to say on most topics....I dunno whether your post is a misunderstanding of what slide and I are talking about and or my way of being sarcastic or even if your just joking yourself...either way, meh.
matts just upset cause his car has the hicups
1 solution N2O otherwise known on the streets as NAAAAAAWWWWWSSSSSSS
nos or ban matt your choice :)
;) I fixed that problem its called "dodgy fuel"!! I need NAAWWSS, i'll take a big one no better make it two!! And Aaron, I need em by tonight ;) the payouts from that movie are endless. I'll take im selling the car for $50 though Jerry, closely followed by: maybe in the next car n20 will make an appearance, who knows ;)
