Thats a big ask... I REALLY WANNA SEE IT NOW...
whats it gonna be, drag/track/targa/street car??
remembering that Rickards has run an 11.06 on his old setup,
I was thinking the same thing. To throw a cat amongst the pigeons, Max Griffith's HR31 being substantially lighter than most GT-Rs, and with 383kw at the treads - I wonder what would happen if they stuck big slicks on that and ran it down the quarter? Rear end squat could be a big problem, but if it could hook up at all it would have to run a good time.
  • Replies 101
Yeah its a big call but when you see the car and its running gear i think you will understand why it was said.
My understanding is that the car came from one of the car companies in Japan and it was a demo car that they had built to show what they are capable of doing.
Now the car has been dyno'd in Melbourne i believe and the figures were similar to Ma'x R31 but the new owner (jedinathan's old man) is having the car changed back to GTR 4wd, which in my book is a wise move with this car if all the stories of it are true.
Would be very interested in seeing them both run the 1/4 and what times they would get and that goes for any other import doing the block these days that has a bit of work done to it. Just take Rickards's car for example, one very tidy import that has had the right mods done and producing some very impressive figures.
:cheers:
I have had a good look at it actually, and I wasn't saying it won't be the goods.
I have no doubt it should be right up there. Lets wait and see what it does.
Ok found some info on the car
The details are as follows:
• This car is (or was) the primary demo car for Yanack Racing in Japan
• Travelled an elapsed 77K klms since manufacture, it has travelled less than 8K klms since an extensive and meticulous rebuild at huge cost to the former owners.
• HKS 2. 7L stroker (8000Km),
• Trust TD07 turbine (1000Km),
• HKS F-Con V professional,ORC twin plate clutch (1000Km),
• OS Giken fast cross transmission (1000Km)
• Tomei 2-way diff,
• Brand new YANACK Racing widebody styling and GT wing ( bodykit worth $10K by itself),
• 7 point roll bar,
• TRUST Oil Cooler ( new),
• HKS boost gage,oil temperature gauge,oil pressure gauge, fuel pressure indicator and exhaust gas temperature indicator,
• oil catch tank,
• Yanack recently spent almost $70K AUD modifying & tuning this car, not including the costs of cosmetics.
• Car is suggested to be close to 600BHP ( 335rwKw) at 1.6bar, but this will be confirmed when dynoed upon landing.
godzilla49jo.jpg[/img]
Yeah i hear what ya saying and im not having a go at you floody. Just saying that its a call that most people would say just from looking at the car.
Ment it as the whole Fast and the Furious thing, got a BOV and a rear wing with some decals and its a 10 second car :(
Ment it as the whole Fast and the Furious thing, got a BOV and a rear wing with some decals and its a 10 second car :)
Well my old man now has his car back in all it's 4wd glory. On a side note - Dave lost 4 points after speeding in it and being nabbed by the police!
GLAD to hear its back on the road, will we see it at DriftMania at all nath???
Im sure Griffo would of loved that to, check ya bill the fine might be added on there jk
haha he obviously couldn't help himself!
Now in regards to being on the road - it's not yet. The best part ofcourse is to try and get it registered with all the gear on the car...which unfortunately wont be in time for drift mania.
BWAHAHAHAHA yeah i recon it would be pretty hard with the right foot to control. its hard enough in my car let alone something like that.
Im sure when its on the road we will see it around. You going to DriftMania nathan???
Yeah I'll be there...if I see any of you guys out can I come up and say hi?
Geez man i dont know, talkin to ya on the net is one thing but in person :confused:
Of course you can man, where not going to bight ( and if we do it wont be hard :innocent: )
Come over and give us a BIG :cuddle: well maybe not a :cuddle: but will be good to talk to a few of you guys in the flesh and not as keyboard warriors :Pimp2:
lol - cool!
  • 1 month later...
Anyone know if nath's old man ever got the car on the road at all, i haven't seen it around :P
Cheers B
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
