Did a search couldn't find exactly what i was looking for. Will RB26 coils out of an R33 GTR fit my R33 GTS cylinder head?
The guy said he has the ignitor on top of the rocker cover so I assume they are S1 (I thought R33s were all inbuilt ignitors??) and I also have the external ignitor on the rocker cover. I am using Motec so wiring isn't a huge issue just need to make sure that the coils work with the Rb25 ignitor.
Also I heard there may be some plug lead length differences??
https://www.sau.com.au/forums/topic/67473-rb26-rb25-coil-difference/
Sweet. Thanks man.
So I shouldn't have any probs with the plug lead part or did you have to swap them over to suit the new coil-plug distance? Or is it the same?
Nope that just went straight in:cheers:
