Guys;
this follows on from a thread on gauge accuracy in an R32 GTR. I understood from a gauge repair place that sometimes if you remove standard gauges (I'm looking at building a custom dash as I don't want to have gauges all over the place) it has undesirable side effects ie I've read a recent thread saying that removal of the oil temp gauge has made the oil press light illuminate but I haven't witnessed this myself.
Can anyone definitively state what is required when replacing the standard gauges in terms of wiring etc? Not concenred about power or sensor connections, but anything that might not be immediately obvious such as a connection between computer and gauge that needs to be maintained etc. In other words are there any traps?
Thanks
Scooby
https://www.sau.com.au/forums/topic/67660-replacing-r32-gtr-oem-gauges/
Hi - having this issue at the moment.
Unplugged the 3 factory 3 din gauges, and the oil light in the dash stays on - upon further investigation, that light shows both warnings for oil press AND oil temp. So, it would appear that when the ECU sees 0V across the oil temp gauge, it throws on the oil light.
So, my thinking is, seeing that I've replaced the 3 gauges with Defi 52mm oil temp, press and water temp gauges with warning, all I need to do is to unplug the lead going to the oil light...
Looking at the (horrible) dash wiring diagram, it seems that if I pull wire 34 going into the dash, this will kill the oil light.
I don't have the car at the moment (will be a few weeks at the shop) so will try it when I get the car back.
Note, justinfox replaced his with the Defi din gauges, and didn't have a problem. Maybe these gauges plug into the factory loom, so no issues?? I can't remember who it was who installed them for him, but maybe a quick call to whoever did it would help too
Hope that helps :P
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
