Hey guys,
I'm planning on opening my own business, by the names of either
"DESVAUX AUTOMOTIVE"
OR
"SD AUTOMOTIVE"
reply bak with any tips on what 2 do in order 2 have a successful business..
cheers...
https://www.sau.com.au/forums/topic/67741-new-business-eventually/
I'd call it SD Automotive, no-one will know how to say Desvaux Automotive... and Desvaux sounds dodgy, no offense if its your surname or whatever.
Dont use SMS chit chat language like "bak" or "2" when you're running your business.. ;-)
  • 1 month later...
Erm, this thread sounds familiar "Smokin_Stevo".....
Wtf are you doing? Spamming your bussiness around all the car forums 10 years early?
Hey guys,
after seeing the Bresciani boys gaining success, (and also due to the fact that i've always wanted 2 own my own business), i have decided 2 eventually open my own automotive workshop.
It will be called
OR
"SD AUTOMOTIVE"
this business will eventually be running in the next decade or so...
it will be especially for high performance cars only
and not just V8's...lol
yeah..
so watch out for it...
feel free to reply back with your comments...
cheers...
smokin_stvo
dude you are a wierdo,
just shutup or start a business.
nobody loves you, we don't care for your mental diarrhea so dont spray it all over the forums.
just register a business name and start trading or stop posting pointless garbage
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
