Here's your chance to own this immaculate R33. Just been sprayed with Blueprint (BA Falcon XR6) colour. This car will be fitted with a Stealth/Drift wing.
Comes with 16" Alloys (White) to be posted soon with pics.
This vehicle is in Sydney.
Description:
- 1994 Nissan Skyline GTS-T
- 117,000kms (Timing Belt Changed)
- Brand New Windscreen
- NISMO Catback Exhaust
- 16" Alloy Wheels
- HID Head Lights
- Engine and Transmission in Good Condition
Now for the good part. This car is only $17,800 Complianced.
https://www.sau.com.au/forums/topic/68054-blueprint-r33-gts-t-bargain/
