  • Replies 64
Ok ill make it simple for some of u , Well at least i think this is what you guys are refering too!
Details :
Yo guys and girls, its that time of year again, Anzac day and the massive Supercruise is on again.
Unlike other years there will be no official meet up place to start the cruise, only an official destination. This is due to the enormous amount of effort to organise meet up, it is easier to just organise a destination point.
This year the event will be held at Albion Park Airport from 12pm onwards.
There will be
BBQ
DRINKS
Ice Cream
Jumping Castle
Aeroplane & Helicopter rides.
Entry is via sticker purchase, cost is $20 per car, tickets can be purchased at entry point. Aall monies raised will go to charity, mainly Childrens Hospital at Westmead. Also Police have been notified about the Event and they will be monitoring it so please be on your best behaviour, there will be no defect setup at this place, but please ppl it only takes 1 idiot to screw an awesome event.
Bring your family, bring any car you like. Look forward to seing you there.
Any enquiries please contact Albert on 0419 430 022
Starts Early .. 12 lunch meetup .. Rise n shine fellaz :D dont have to big of a weekend.
I hope im there , have my car booked into BD4's on thurs so lets hope its out by friday .
Meet up would be a good idea. i would say Meet at Waitara Macca (as its a lil bigger then Thornleigh i think , not from there :D ) , and for the westies like me lets try Windsor rd, Near the Ettamoga pub and the Maccaz there if u want. for others sort it out amounst urself :wassup:
Starts Early .. 12 lunch meetup .. Rise n shine fellaz :P dont have to big of a weekend.
there wont be a meet up point but i can imagine people will goto kingsgrove shell and roselands car park to meet anyway.
i go every year, kicks arss!!!
you boys going if so you going down king georges??
hey mate
if i get my defect cleared up wanna meet at shell again?
gday all.
im from the castle hill area, and in regards to the supercruise, me and a few mates r meeting up at the coles carpark at bella vista, its a huge carpark!!! its located on norwest boulevard off old windsor rd.
we r meeting there at 9am, for a 9:30-10am departure down the coast, if anyone is interested, let me know or just rock up!!
if u wanna know who i am, i have the burgundy/maroon, r32gtst, with gtr front end, green [P] plates!!
take it easy, hope to meet some of u guys soon!!
cheers Giffo.
Im headed to Kingsgrove for 10, unofficial meeting point i hear, Giffo If you guys wanna head to kingsgrove from coles, ill meet you at norwest. Not sure how many cars with me but at least 3, prolly more.
Bizzr you Lozer :spank: my place 830 dont have a big sun night!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
