RB26DETT Standard Cams $300
Good upgrade for RB20/25. Excellent condition.
Front Facing Intake Plenum RB20 $50
Front Pipe needs to be welded on
RB20DET AFM + Polished Stainless Steel Pipe $150
AFM with plug +
Polished Stainless pipe from AFM to Air filter SOLD
Will sell seperate if need be.
HKS Blow Off Valve $50 SOLD
RB20DET Standard ECU $150
RB20DET Standard Turbo $200
Turbo done 80000 Km. No leaks, minimal shaft play.
Turbo never ran over 12psi.
R32 GTST Standard Suspension $200
Suspension only done 80000Km
how much for the turbo to afm pipe on its on?
is the pipe the same size as in the inlet on the turbo? or do ou need to get like silicon hose reducer or something
im pretty interested.
Shorter intercooling pipe which means.................less lag!!  They work better than GTR ones.
shorter cooler piping/space considerations sure, but im a little hesitant about the internal airflow characteristics of the plenum catchments since they were designed to receive air from the stock throttle position.
Are the internals unmodified? Does anyone have an idea or opinion on this?
This is not an opinion thread, if you want to discuss the pro and cons of a FF plenum there are a couple of threads on the Forced Induction Section.
The plenum is for sale as is, it was an unfinished project, as i did not have the time to try it out. Sometimes ppl should experiment a little to see how the car responds to hardware changes instead of expecting pretty number on a Dyno sheet.
:P
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
