Hi there guys, I'm selling a set of ALT Blade Rims which came off my GTiR. So it'll fit anyone elses R and I'm sure other Pulsars as well (the stud pattern is 4x100). I believe other cars such as Civics, Excels etc use the same stud pattern as well?
They're currently not at my house but at my brothers so I'll have to get a check on the tyre info, but I believe they were Nexen brand and 2 of them had about 90% tread and the other 2 were about the same except they were pretty worn on the inside.
http://www.altwheels.com/Products/at296.htm
Well price is $950 for the rims and tyres but obviously negotiable. Make an offer guys.
I don't have any webspace so would anybody want to host it for me? Other than that you can see the wheels at the url I provided above.
Any queries PM, call 0403578014 or email/MSN at [email protected]
Cheers,
Andy
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
