complete r32 gtr interior
front seats rear seats door trims rear trims 1200 ono SOLD
cluster/instriment panel speedo goes to 260km $200ono
all 4 lowered springs and struts
AVS Model 5 White Rims 235/45R17 tyres $1000
rb20det/ turbo/ecu/manual 4wd gearbox/loom 1200ono 4 whole package pm 4 more info
other undamaged stuff
auto to manual converson parts 300 ono
4wd computers
ps pump $50
aircon compressor $50
radiator $100
side indicators $30
dash wateva :D
diff $200
carpet $50
door sil trims
rearlights
crossmember
all 4 brakes/disc's caplipers waterelse ya need $500
every single panel is dintted in some way except pasanger door
ALSO GOT R33 GUARDS MUST GET RID OFF BEST PRICE GETS THEM
ALL PRICES ARE ONO
anythin else just ask might still have it
$100 donation wil be made to sau once all/most this stuff is sold
  • Replies 80
Hey man,
Are you using a GTR dash????
Chasing the dash surround with the didgital clock..... has wiper controls and head light controls on it..............
Its the plastic fasica that runs on the edge of the instraments binnicle.....
Mike
In the dash - the two top defrosting vent inserts (the two vents that run the length of the windscreen)... got them?
Order them tru nissan, i did, u get them knew and they arent that expensive...
the point i was trying to make, sorry for hijacking the thread, thought it could help a few people out tho.
Oh yeah old mate, i would take your interior but im not in sydney :(
26GTS :cheers:
How much for GTS4 front & rear diffs (must be 4.3:1 ratio)?
How much for GTR 260klm dash?
Get back to me ASAP, Thanks.
front seats rear seats door trims rear trims the center console bit  1200 ono
also have cluster/instriment panel speedo goes to 260kmh
wreaking gtst4  everything 4 sale
lights broken front guards damaged
roof squashed
has coil overs  $700
17 inch AVS white mags n tyres $1000
rb20det/aftermarket turbo/after market ecu/manual 4wd gearbox/loom   $2500  4 whole package pm 4 more info
everything :cheers:
anything else give me a yell may have it
