While I've been trying to ge tthe hub off the front of my car some suspension component has been resting heavily on the tie rod end. A lot of grease came out - I cant see any splits. Can I just add some grease again. If I pop the rubber bit up I can probably fit something in there to add a bit of grease (Due to the taper). This happened to anyone before??
Thanks :ufo:
https://www.sau.com.au/forums/topic/69074-tie-rod-end-grease/
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
