Hi Guys,
Before Auto Salon I had some special caps made up for my wheels, unfortunately lastnight one of them decided to go walkies? fell off or stolen???? anywayz i bought the name part (inner circle) of the caps from wheels world the store that used to be next to speed works on hay street in Subiaco he said he still had 2 left spare for me if i ever needed more.... i should have grabbed em then!.
I URGENTLY need to know if he has re opened or if there is some way i can get back in contact with the owner. He was a very nice guy and was always willing to hellp.
If any of you guys know of a way for me to get in contact with the owner or if you know where he is relocated i would be Very appreciative! Otherwise I am up for HUNDREDS trying to get a whole new set of caps made up!!!
Thanks muchly in advance!:uh-huh:
Daniel
https://www.sau.com.au/forums/topic/6936-urgent-help-needed-pleeaaseee/
Thanks Dude!
Yeah i managed to get through to John!
Good and bad news..
Good news: I got through To him and he remembered me and the exact caps i was after
Bad news: Most of the stuff from his old store will take a while for him to locate :-( could be 2 or so weeks till i find out whether or not i will be able to get the missing cap:-(
Thanks for the help dude!
B the way guys they have a special opening day sausage sizzle and all on Saturday 14th of December... address is mentioned above...sausage sizzle and all! Yummo!
Guest GR33DyMANGO
Originally posted by Strich9ine
Hey Dan,
I've heard Speedworks re-opened with joint premises with Wheels world at
Speedworks, 4A Carbon Court Osbourne Park
Hope this helps dude... sorry, I dont know much more.
-Kym.
how do u know that wheels world is also in on this speedworks venture? i thought he went out of business???
Originally posted by Pva_Glue
dang those caps looked sweet...
how they went walkabout? some one took them?
is it hard to take them off? should have cap lock! :lol:
cheers
Joe
Yeah I spoke to John,
I have to call him next week to see if he can get another centre cap in then if so i have to wait another week for a whole new entire cap to be made up...bugger me! if not might have to get a whole new set made up...I don't want to think about that right now...i don't feell like crying! HAAHA yeah I already have lock nuts hmmm cap lock nuts i will have to invent!! :-)
I have my fingers crossed that he can get in or find the same inner Intraa caps I had before!
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
