Hi Guys,
Before Auto Salon I had some special caps made up for my wheels, unfortunately lastnight one of them decided to go walkies? fell off or stolen???? anywayz i bought the name part (inner circle) of the caps from wheels world the store that used to be next to speed works on hay street in Subiaco he said he still had 2 left spare for me if i ever needed more.... i should have grabbed em then!.
I URGENTLY need to know if he has re opened or if there is some way i can get back in contact with the owner. He was a very nice guy and was always willing to hellp.
If any of you guys know of a way for me to get in contact with the owner or if you know where he is relocated i would be Very appreciative! Otherwise I am up for HUNDREDS trying to get a whole new set of caps made up!!!
Thanks muchly in advance!:uh-huh:
Daniel
https://www.sau.com.au/forums/topic/6936-urgent-help-needed-pleeaaseee/
Thanks Dude!
Yeah i managed to get through to John!
Good and bad news..
Good news: I got through To him and he remembered me and the exact caps i was after
Bad news: Most of the stuff from his old store will take a while for him to locate :-( could be 2 or so weeks till i find out whether or not i will be able to get the missing cap:-(
Thanks for the help dude!
B the way guys they have a special opening day sausage sizzle and all on Saturday 14th of December... address is mentioned above...sausage sizzle and all! Yummo!
Guest GR33DyMANGO
Originally posted by Strich9ine
Hey Dan,
I've heard Speedworks re-opened with joint premises with Wheels world at
Speedworks, 4A Carbon Court Osbourne Park
Hope this helps dude... sorry, I dont know much more.
-Kym.
how do u know that wheels world is also in on this speedworks venture? i thought he went out of business???
Originally posted by Pva_Glue
dang those caps looked sweet...
how they went walkabout? some one took them?
is it hard to take them off? should have cap lock! :lol:
cheers
Joe
Yeah I spoke to John,
I have to call him next week to see if he can get another centre cap in then if so i have to wait another week for a whole new entire cap to be made up...bugger me! if not might have to get a whole new set made up...I don't want to think about that right now...i don't feell like crying! HAAHA yeah I already have lock nuts hmmm cap lock nuts i will have to invent!! :-)
I have my fingers crossed that he can get in or find the same inner Intraa caps I had before!
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
