  • Replies 94
Looks good, the only annoying thing about it is the legality of it.
Fortunately I live in an area where I dont have to worry bout it :)
Having the 3 openings gives you the option to plumb it how you like it. So you can plumb it to avoid any legal issues.
Provided it is fully plumbed back you should't have any legal issues, although anything non standard is considered illegal until you get an engineers certificate.
You could always paint it black and say its fo the power steering or something :cheers:
I got the CAI from the forum. Need a snorkel that will fit over the cooler piping and gotta also set up an intake from the front bar to under the CAI (through the old cooler piping hole.)
I'll probably relocate the OCT after I do some other things.
I didnt have to drill so it was an easy install.
:cheers:
With a setup up like that I dont think the catch can would be catching a lot as the blow by gasses will be escaping through the shortest route. So in this case with hoses connected on top of the can the gasses will never see the bottom as they will escape throgh the filter of the can so it doesn't matter if the can is baffled or not.
Please correct me if i'm wrong.
I'm after a catch can hope this fits an s14 if u could pm me your acc details will deposit the money in to your acc,
Need 10 people to qualify this group buy of oil catch can kits.
- Unbaffled but can be easily done with steel wool and a stocking (SK handy tip number 1954) :rofl:
- comes with 15mm or 12mm hose (1.2m) - please specify.
- hose clamps
- filter
- 800ml
Usefull installation links - click here - and here - and here
Price for 10 buyers - $80 delivered (Australia only)
Closing - Wednesday 20th April. Payment due Friday 22nd April.
1/ 400kwgtr
2/ Gizmo73
3/ Abo Bob
4/ (B1) MR_fanny
5/ aussnick
6/ [[d a n n y]]
7/ gtrGhosTDoGG11
8/ GIGOLO
9/ voona
10/
Regardless of how its plumbed if that air filter remains connected kiss your ass goodbye when a cop pops your bonnet.
I live in a quiet area.
I have a cop that lives about 100 metres from my house and he walked past my house as I was installing it. He couldnt care less.
:rofl:
My money is in too, transfered on monday, can you confirm please  :-)
Payment received :D
Keep an eye on the first post as I will edit the payment and shipping status for everyone as we go.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
