Hello everyone! Just got my first skyline (r32 gtst) and I am so happy about it. Got to admit I don't really know much about cars :Oops: and its internal workings though so a few questions regarding the car
1. Sometimes the HICAS light just come on/flickers on and off the seller said his mechanic say there's nothing wrong with the car but I just wanted to make sure whether I had turned on some button in the car or something. By the way, what is HICAS?
2. How many immobilisers are there in my car? Is there a procedure to check whether they exist in the car?
3. What do you use to keep the windscreen from misting up during cold nights or driving through fog?
4. Is there supposed to be an official skyline australia club that i can sign up for or something? Read of some people even having a membership card but I just couldn't find any information on this website.
Got a couple more questions in my head but just couldn't remember them. This will have to do for now. Thanks for any inputs!
Hey I see your from Sydney, so you can have a read here http://www.skylinesaustralia.com/forums/sh...ead.php?t=44115
as for the HICAS problem.. I think if you have an aftermarket steeringwheel fitted this can cause it ;)
ps.. wheres the pics :P
edit
HIcas is - High Capacity Actively-Controled Steering ( i think lol)
1: do diagnostics (you will find in the diy/faq area
2: what alarm do you have ?
3: a combitation of windscreen wipers and dimister should solve it :P
4: Become a Registered NSW Mamber for club events (the link slim posted)
....By the way, what is HICAS?
HICAS is a 4 wheel steer controller, & the unit can be found in your boot. It normally comes into to play when you reach 80km/h.
It depends on your brand, good ones normally have at least 3point or more (eg. Viper, Cheetah). Search the net if you know which model/ brand, otherwise go to a car alarm specialist & ask.
http://www.skylinesaustralia.com/forums/sh...713#post1253713
This link is for membership to Skylines Australia (NSW).
And I would always use the aircon for demisting the windscreen. It's good to run your aircon once a week anyway. Keeps it running well.
If the powersteering fluid level is low it will cause the HICAS light to come on occasionally, as the rear steering feeds of the same reservoir as the front in R32's.
It also could just be a electrical connection problem...
Yeah it came with an aftermkt steering wheel, guess i'll have to trust the seller about what he syas then.
The alarm is a Rhino GTS. The website states that there's a 2 point engine immobiliser. Read somewhere else that insurance companies need at least a 3 point one if not a theft claim will not be valid? If thats the case I might need to change it pity though it was only installed in feb this yr.
Combo of wipers and demisters and the air con towards the windscreen way? Was thinking of any products that might prevent the window of misting up in the first place. Didn't really want to spit on my beloved skyline's windscreens the way divers spit on their face goggles before they go into the water. :spew:
Sending in the application form tomorrow! :wavey:
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
