  • Replies 71
just drove to and from syd in my R32, so I don't see why halfway should be a problem... might be a longer trip for the syd people, but we can host an event at Winton pretty easily...
Yeah exactly, start small (ish) and see how it goes from there.
That way we can suss out any issues that would possibly arise from bringing a larger number of people together in one place.
And prob gain an idea of what sort of size venue we would need for it, and what sort of things for entertainment instead of standing around like twats for half a day :D
last time I did the drive to Albury a Kangaroo landed through my windscreen.
Liz im starting to think that you target little cute inosent animals, First it was a "wombat" on the bell line cruise, now a "kangaroo" what next a hippopotomus ?!?!?! JEBUS ! :)
I know canberra really well as well... its the easist drive. If we were going to go to meet with the melb ppl, we could all drive to Gundagi and get photos of the cars with the dog on the tukkerbox. :wassup:
