  • Replies 412
hmm.. so many meets though! i dunno... we can meet at the entrance to the nasho.. there is a long stretch where about 20 cars could sit and wait.. and then head off from there?
Moanie, yeah there is just at the start of the nasho where the ticket box is. There is another lane that sites next to it and some space on the side of the road so we dont interfear with traffic.
It doesnt really bother me too much, im happy to do whatever. But good idea. I say we leave waratah street at 10:05 just to be sure there are no late comers! :wassup:
