Just curious about AFM options for an RB30-DET. Leaning towards running a GT30 turbs, on about 18-20psi, using a PowerFC to tune it all. Just wondering if I would be better off runing a Q45 AFM, or twin Z32 or RB20's?
Can the PowerFC run two AFM's at once?
Steve
https://www.sau.com.au/forums/topic/71391-rb30-afm-options/
BEFORE YOU BUY THE Q45.......
Interesting thread guys. I am just about to tune my freshly built RB25/30 and am going to find out how much my z32 afm will support with the current set-up! Matt Loweth, an owner of an rb25/30 (for sale at the mo) on this forum has made around 340ish rwkw with a z32 afm. Correct me if I’m wrong, but its limits can differ depending on how "efficient" the engine is if you get my meaning. Matt does have gtr cams, which may help with this efficiency....food for thought..
https://www.sau.com.au/forums/topic/71391-rb30-afm-options/#findComment-1323416
You can use either the z32 or the Q45. The Q45 just has more resolution to tune with if you start talking big numbers....ie over 350rwkw i would use it.
They both cost around the same, just one has more head room for later on. I bought the Q45 because it cost the same as the z32's at the time, and i knew id be going for around 350rwkw....
https://www.sau.com.au/forums/topic/71391-rb30-afm-options/#findComment-1324004
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
