Tried to contact Mario who built and hosted their site? His Supra was always getting bodywork done there, might be of some help?
You will find his supra get work done at Millenium motorsports now if that helps. Millenium get thier bodywork done at DMD. ;)
I know this, but it was easier explaning it the way I did :rofl:
SupraMario here on friends account ...
Millennium is a performance workshop
theyre not an entity like ares / dmd that do full show cars and what not,
theyre the same as subzero / APC / and the like ..
My supra has had its work done all at ares, and any future things ill sort out through panel beating friends, not DMD.
The millennium cars you might be referring to will be the workers there that had work done by DMD, its a bit far fetched to say that all work is referred there..
then without gossip where would most forums be :)
