GTST VSPEC,
Have a look in the wasteland under summoner's post about the perthhotcars update, there is a vid of you beating a zx and running a 14.0..
There is also one of a purple r33 beating that white sti with personal plates but unfortunately it wasn't me....
Brett
  • Replies 89
EVL R33,
Thanks for that Brett, it quite weird looking at it from a spectators point-of-view. Luckily I had the legs on the 300, cause I still didn't get a good launch. I'm hoping to see you next Wednesday, where we can start to improve our times, me more than you.
See'ya:burnout:
Originally posted by GTS-t VSPEC
It will be good fun racing one another, as we should be pretty close.
Not sure if im gonna head down yet, don't think I should give my cluth so much punishment so soon. Don't really want to smoke up my clutch again, I prefere the smell of burnt rubber. I'll be down the following week though if your interested.
Hicks,
I thought this is the last Wednesday before Christmas for the drags. Your new clutch should hold up no problems, it won't matter if you give it shit now or later, so you may aswell come down. It should be at least twice as strong as the factory clutch and that took a while before it was destroyed.
See'ya:burnout:
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
