Group buy - Recaro style seats only $550 a pair or $300 singles - VIC
hey i might be interested about freight have you tried busfreight? i dont know their web address but as i was going to buy a set of coil overs and they said the price would be 68 dollars for delivery
  • Replies 46
oh yeah how much would you do for a red bucket with no rail as i have a FC not a skyline
Hi mate, I can do for $640 delivered to you. They come with universal rails and then you have to mod them. (i only have the seats in black as pictured in my first post)
To get rails made up the car need to be there. In my Exa the floor pan isn't flat ether. What they did is cut up the stock rails and welded all the points onto the universal rails where they needed to be to suit my floor pan. Its not that hard even with an uneven floor pan.
Cheers
Greg
  • 4 weeks later...
seats are now available at $499 a pair..
Have a look on our website here: http://www.gktech.com.au/products/?id=39
cheers
Greg Kruse - GK Techologies
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
    • hi mate, HKS cooler piping still available by any chance?
