  • Replies 50
mate i got a quote and its gonna cost 200-250 to send 2 perth and thats insured etc etc and i thought it was gnona b more considering its a 100kg package
but mate if u want it sent 2 perth its gonna cost u 2500
sorry but 2300 is the lowest ill go
does any1 kno the best way yo get em 2 perth??
Infact... I just got a quote for shipping some tyres and an exhaust to Perth... $145 + 20 bucks for wrapping of the tyres.
I called Pack and Save in Freo. Mine was coming from Brisbane.
i reckon shipping charges could be around 100 bucks  but no worries mate, if u change your mind my offer stands
well as u can c shipping is now from 145 and xtra for wrapping etc.
i cant go any lower than 2300 for the rims so sorry tehy r going back on the car today unless u can find some1 that will ship em for $100 etc.
Nathan
oh sweet mate thanks for that
ill give em a call
Nathan
shipping from perth to sydney cost me $100 for my 20s through TNT
btw just to clear up questions people have asked
they are not a jap rim and they are one peice
and seeing as they are a toyota offset you might need spacers to fit on a nissan
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
