FS: VDO Dayton MS 4200 RS ( http://www.vdodayton.com/ ) in Excellent Condition. Currently still in the car functioning perfectly except no way to test the navigation because the map CD has not yet been unlocked so suitable for anywhere in Aust. :) (you pay per city I believe)
4x40W
Intelligent destination input
POI browser
Quick access street search
ZIP code entry
Comprehensive icon and voice guidance
21 Voices (male or female) in 9 languages
High speed processor system
Adaptable display brightness
Trip computer
Digital sound processor
7 Sound presets
Speed dependant volume control
Digital cd changer control
Detachable flip down front
Security code able
Comes with language change CD and Whereis Navigation CD *NEVER BEEN USED OR REGISTERED* Original box and manual.
Postage at buyer’s expense deliverable in SE Melbourne
$1000ono
https://www.sau.com.au/forums/topic/72218-fs-vdo-dayton-ms-4200-rs/
hey budy would you consider a swap for a top of the range alpine HU? i have a Alpine CDA-7998R Bass Engine PRO CD/MP3 Player/Tuner with all the fruit, only had it 3 months and it is absolutely killer, just wanted to get some nav in the car that all.
let me know... will pay the postage :D
Yes I will consider it just checking specs and ability to integrate with the rest of my system which I am pretty sure it will perfectly ;) I'll put up a pic of the actual unit tonight, could you send me a pic of the 7998 - [email protected]
Basically you register it and they give you a code that you put into the HU and it decodes the maps that you have paid for (as with any GPS system it's the maps that cost the $$$ the actual GPS positioning is free). The unit comes with the manual and discs so that won't be a problem for you. It has some really cool features like the trip comp, speed limiter (good to set for when others drive your car :( ) etc. The Alpine unit will fit into my plans very nicely so if you like the VDO unit and approve of it's condition (which is excellent) I'll have it professionally (Stylyn or Tower Audio) removed and ready to send to you registered and insured.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
