  • Replies 128
Paul u drive like a MANIAC! :D
heheheh
But then again i tail gate :)
Yes excellent boys, i swear there was just so many ppl there, i wish we could of slow everything down hheheheheh
i didn't really get to tok to you Paul or Minh, i didn't get to tok to alot of ppl actually heheheh
just too big of a crowd to handle,
How u guys feel about waiting now!!?? hahaha
Now u know how i feel every freekin Monday,
Fanx Nick, love the springs gonna put them on this weekend,
Have fun in JAPAN loz!! Make sure u do the TOP SECRET GTR exhuast pipe and show us!!
Peace out fellas
Donnie
https://www.sau.com.au/forums/topic/7284-great-dinner/#findComment-107239
Maniac (n.) [may-nee-ak]:
1. An insane person.
2. A person who has an excessive enthusiasm or desire for something: a sports maniac.
3. A person who acts in a wildly irresponsible way: maniacs on the highway.
4. URMINE
hahaha. you are ****in crazzzzzzzzzy man :)
good to meet u too bro, love the paint!
what a sick night, it was fully hectic bro, i had a mad time, couldnt believe how many ppl came out on a wednesday night :)
now remember boys, DONT FORGET TO FLUSH THE TOILET
:D
https://www.sau.com.au/forums/topic/7284-great-dinner/#findComment-107245
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
