  • Replies 128
Originally posted by | hype^ |
$ BLING $ BLING $
damn i wouldda came if my dad didnt f**k off with the keys to my sky..
soooo i missed out as usual!! prob best anyway, im running pretty low on tissues as it is.. :P
ahh well skank hunting paid off :uh-huh:
Damn you !Eugene I was waiting for you to come!!!:)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
