My air fuel ratio gauge shows that at idle speed, the lights are on between lean and storch, however when the engine revs higher, around 3000-3500 it shows rich. Anyone know is it meant to do this or there is something wrong with my engine?? thanks
That's pretty much normal. I'm guessing you're using a normal O2 sensor? They only run 0-1v which isn't very accurate but most RB's will show rich above idle running standard management. Nissan ECU's tend to run rich which is one reason SAFC's and aftermarket ECU's show power improvements.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
