Item: 3x 2 Million Colour Full Hektik LED Neons For Undercar,12 sequence
Website: Nil.
Item Condition: Brand New. In Box. Unopened. Never Used.
Reason for Selling: dont want them
Price and Payment Conditions: $550 delivered $400 NOW!
Extra Info: (2 x 36" + 2 x 48") with alarm style remote
12 different sequences
Poly Carbonated,Resin Coated
Pictures: ADDED!
Contact Details: PM ME or SMS 0422859515
MUST SELL BY THURSDAY!!!! GOTTA MAKE WAY FOR NEW STOCK!!!!
NORMAL RETAIL IS $999
https://www.sau.com.au/forums/topic/73668-one-off-sale-only-3-available/
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
